OI Roundtable
Got Questions Get Answers => Troubleshooting 101 => Topic started by: zigmund on November 06, 2017, 08:57:PM
Title: Pratt and Whitney Tape-O-Matic
Post by: zigmund on November 06, 2017, 08:57:PM
Hello guys,
I know this is an industrial long-shot, but does anyone have technical info or a service manual for any of the old Pratt and Whitney Tape-O-Matic equipment. I have an old tape-o-matic machine with a lot of tapes.
The machine is rock solid and hasn't been used in years. I'm hoping to resurrect this system with any investment right now. I can invest money into a controls upgrade as early as next year, but for now I'm hoping to get the tape portion of the control working again.
The tape reader won't read the tapes, reels turn but the tape just feeds through and the controls don't respond. All the servos on the machine work fine in manual mode.
Any tape-o-matic tech support would be greatly appreciated. Thank You!
Title: Re: Pratt and Whitney Tape-O-Matic
Post by: alexrodgers on November 14, 2017, 09:04:PM
Here's a classic NC tape reader:
(http://www.obsoleteindustrial.com/roundtable/gallery/2_14_11_17_9_01_35.jpeg)
I have an old tape-o-matic control manual, give me some time and I'll post what I can. It's falling apart, and I don't refer back to it all that often these days.
Post by: alexrodgers on November 15, 2017, 08:43:PM
Pratt and Whitney Tape-o-Matic Troubleshooting Guide, Faults, and Remedies
(http://www.obsoleteindustrial.com/roundtable/gallery/2_15_11_17_6_37_56.jpeg)
PROBLEM: No High Speed in both plus and minus jog, medium and low speed OK CAUSE: fault in Pilot Relay REMEDY: X Axis - Cards A01, D12 and Y Axis - Cards A23, D16
PROBLEM: No High Speed in both plus and minus jog, medium and low speed OK CAUSE: overload tripped REMEDY: X Axis - Reset Overload #1, Overload #2 in Panel #1 or Y Axis -  Reset Overload #3, Overload #4 in Panel #1
PROBLEM: No Hi Speed in Plus Jog Only CAUSE: Fault in Motor Logic REMEDY: X Axis - Cards A01, F03, H16, F06, F07 or Y Axis - Cars A23, F19, F22, F23, H32
PROBLEM: No Hi Speed in Plus Jog Only CAUSE:  Fault in Motor Logic REMEDY:  X Axis - Cards A01, F08, H01, F07, F03 or Y Axis - Cars A23, F19, F23, F24
PROBLEM: No Medium and No Low Speed in Plus and Minus Jog (X and Y Axes) CAUSE: Fault in Oscillator (can be checked with a proboscope) REMEDY: Cards D27, D28, D31
PROBLEM: No Medium and No Low Speed in Plus and Minus Jog (Either X or Y Axes) CAUSE: Bind in Lead Screw Coupling REMEDY: Check alignment of coupling rods to slide (loose huts)  AC motor belt too tight
PROBLEM: Low Torque or Stepping Motor Oscillation CAUSE: Loose Connections in Stepping motor Circuit  REMEDY: Check Field Current Resistor Terminals on #4 Panel or Check the terminal connections of diodes on machine terminal board (rear of machine base)
Post by: alexrodgers on November 15, 2017, 09:23:PM
(http://www.obsoleteindustrial.com/roundtable/gallery/2_15_11_17_6_22_20.jpeg)
PROBLEM: Low Torque or Stepping Motor Oscillation CAUSE: Low +14V Supply REMEDY: Loose generator belt
PROBLEM: Low Torque or Stepping Motor Oscillation CAUSE: X Axis Amplifier REMEDY: Cards A02, A03, A04, A05, A07
PROBLEM: Low Torque or Stepping Motor Oscillation CAUSE: Related Control Logic REMEDY: Cards F04, F08, F09, G02, G04, G05, E01, E02, F05, F06, F10, F11, F12, F13, F14, G07, G10, G12, G14
PROBLEM: Low Torque or Stepping Motor Oscillation CAUSE: Y Axis Amplifier REMEDY: Cards A17, A19, A20, A21, A22
PROBLEM: Low Torque or Stepping Motor Oscillation CAUSE: Related Logic REMEDY: Cards E17, E18, F19, F20, F21, F22, F23, F24, F25, F26, F27, F28, F29, F30, F31, F32, G18, G21, G22, G23, H25
PROBLEM: High Speed Only when Calling for Medium or Low CAUSE: Fault in Motor Logic REMEDY: Cards
PROBLEM: High Speed Hunting CAUSE: No Dynamic Braking REMEDY: X Axis - Check 1 Cap, 2 Cap, and Connections #3 Panel or Y Axis - Check 3 Cap, 4 Cap, and Connections #3 Panel
PROBLEM: High Speed Hunting CAUSE: Fault in Motor Logic REMEDY: (see preceding troubleshooting checks)
PROBLEM: No Set Light when Both X and Y Setup Buttons are depressed CAUSE: Failed Set Lamp or Related Logic REMEDY: Replace Lamp or Cards D08, D12, D14, D15, E30, F01, F17
PROBLEM: No Set Light when Both X and Y Setup Buttons are depressed CAUSE: Fault in Clock Oscillator (Can be Checked with a Proboscope) REMEDY: Cards B14, B15, B16, B17
PROBLEM: No Set Light when Both X and Y Setup Buttons are depressed CAUSE: Loss of 1 or more clock signals due to 1 or more line drivers REMEDY: Cards A11, A12, A13, A14
PROBLEM: No Set Light when Both X and Y Setup Buttons are depressed CAUSE: Fault in Marker Generator (Can be Checked with a Proboscope) REMEDY: Cards E04, E05, E06, E07, E08, E09, E10, F02, F03, F06, F08, F09, F11, F12, F13, F14, F15, F16, F18, F19, F2, F24, F25, F27, F28, F29, F32
PROBLEM: No Set Light when Both X and Y Setup Buttons are depressed CAUSE: Faults in Recirculation Gate REMEDY: X Axis - Card G07 or Y Axis - Card G23
PROBLEM: No Set Light when Both X and Y Setup Buttons are depressed CAUSE: Fault in Setup Gate REMEDY: X Axis - Cards G08, H10 or Y Axis - G24, H26
PROBLEM: No Set Light when Both X and Y Setup Buttons are depressed CAUSE: Fault in Copy Gate REMEDY: X Axis - Cards G07 or Y Axis - G23
PROBLEM: No Set Light when Both X and Y Setup Buttons are depressed CAUSE: Fault in Special Set Up Gate REMEDY: X Axis - Card H11, H12 or Y Axis - Cards H27, H28
(http://www.obsoleteindustrial.com/roundtable/gallery/2_15_11_17_6_27_46.jpeg)
Post by: zigmund on November 16, 2017, 05:44:AM
Thanks for posting the troubleshooting tips, they may come in handy down the road. My problem at the moment all lies within the tape reader. It just ignores the tape and feeds it through.
Post by: alexrodgers on November 16, 2017, 06:55:PM
Quote from: zigmund on November 16, 2017, 05:44:AM
If your tape reader has the bulb in the reader head, it may just need to be replaced.  If the bulb is burned out, it obviously needs replacing. But I have also seen the bulb get dirty or dim and still light up, yet it doesn't produce enough light to register the tape. The bulbs I'm thinking of looked like an old dome light bulb out of a 1970's Chevy. I think it may have even been a 12V bulb.
Post by: alexrodgers on February 06, 2018, 04:25:AM
Here is detailed tape reader info from the manual, I'm not sure if this will help you at this point...
GENERAL DESCRIPTION
The Tape Reader is a motor driven device which is capable of reading
tape in either direction at a rate of 60 characters per second. However
a nominal rate of 50 cycles per second has been established for this
machine. As shown in Figure 10-I, the basic mechanism is comprised
of a series of sprockets (free rotating star wheels) which ride on top of the
tape. The points of the star wheel, which drop into the punched tape holes,
actuate the reeds of a switching arrangement which are equivalent to single
pole double throw switches. The tape itself is driven by a clutch operated
capstan (bidirectional) which is controlled by pulse signals from the tape
control system. The motor itself is continuously operated in one direction.
TAPE READ HEAD
As the capstan moves the tape through the read head, the tape is fed and
taken up so a,s to provide approximately 120 degrees wrap on the capstan
(see illustration A & B). This retards elongation of sprocket holes in
tapes that must be read hundreds of times. The strippers on either side
of the capstan prevent the tape from wrapping around the capstan.
Holes in the tape are sensed by the five point star wheels. Spring
pressure applied to the star wheel lever by each movable contact, holds
the star wheel lightly against the tape.
(http://www.obsoleteindustrial.com/photos/tape-reader-punched-tape.jpg)
As shown in Figure 10-1, when a no-hole condition is sensed, the star
wheel rides the tape on two of its points, and the movable contact is
switched to the upper, normally closed (N/C) position. When a hole is
sensed (with the tape moving in either direction), one of the star wheel
points drops through the hole and the movable contact is switched downward
to the normally open (N/O) position. Therefore, an electric pulse
delivered to the movable contact wire (common) will be conducted to the
N/C terminal if a no-hole is sensed or to the N/O terminal if a hole is
sensed.
By definition, the normally closed contact (N/C) is that contact which
is closed when the star wheel reads a no-hole condition on the tape.
Similarly, the normally open (N/O) contact is closed when the star wheel
reads a hole in the tape.
(http://www.obsoleteindustrial.com/photos/obsolete-tape-reader.jpg)
MOTOR AND CAPSTAN DRIVE
Drive power is transmitted to the input shaft by a timing belt, and
then to the two clutch assemblies by idler bevel gears. When the tape
is not being moved, an armature on each of two escapement assemblies
engages a tooth of the escapement wheel on the corresponding clutch
assembly, causing the clutches to slip. When the tape is to be advanced
(capstan rotation counterclockwise), an electric pulse energizes the
electromagnet on the forward escapement assembly disengaging the
a,rmature from the escapement wheel and permitting the forward clutch
assembly to rotate . Rotation of the clutch assembly transfers torque
from the clutch through the differential to the capstan shaft. When the
escapement coil is deenergized, allowing the armature to drop and
engage the next tooth of the escapement wheel, the capstan is stopped
in position to read the next character.
ELECTRICAL OPERATION
ESCAPEMENT OPERATION
To advance the tape (capstan rotation counterclockwise), a drive pulse
is a,pplied to the for.ward escapement assembly. The energized
electromagnet disengages the armature from the escapement wheel
allowing the clutch assembly to rotate. Similarly, the tape may be
moved in a reverse direction by pulsing the rever`se escapement
assembly.
SWITCHING ACTION
Switches in each of the 8 channels may be ''read" by introducing a
pulse to the common (Movable) contact. If a pulse is transmitted
throught the normally closed (N/C) contacts to the output, the tape
does not have a hole in that particular read position. On the other
hand, if the pulse is transmitted to the output through the normally
open (N/O) contacts, a hole is sensed.
TIMING
Figure 10-3 shows the timing relationships and pulse duration requirements
of the Tape Reader. To start a cycle, a pulse (as applicable)
4. 5 milliseconds long is applied to either electromagnet which
momentarily disengages the armature from the escapement wheel in
the clutch a.ssembly. The clutch a,ssembly responds immedia,tely, and
the torque transmitted through the differentia,1 rotates the read head
capstan. As the tape is moved over the capstan, it is read by the star
wheels. If holes are read, the movable contacts will be switched from
the normally closed to the normally open position. However, due to
the mechanical delay of the reader, contact switching occurs between 7
and 14 milliseconds after the drive pulse has been applied.
CYCLE LENGTH LIMITATIONS
All the Timing discussion and the Timing Diagram is based on:
Maximum reading rate of 60 characters per second.
Drive motor speed of 1725 I.pin.
Drive pulse of 14 volts amplitude and 4. 5 milliseconds duration.
Under these conditions, the minimum time duration of one cycle is
16. 7 milliseconds, i. e. drive pulses must be at least 16. 7 milliseconds
apart (leading edge to leading edge).
TAPE READER MAINTENANCE
LUBRICATION
loo hours - I drop DC-200 silicon lubricant to each of motor cups.
200 hours - 1 drop DC-200 silicon lubricant to each clutch a.nd hole
in the frame members.
The escape lever fulcrum should be lubricated with moly-cote or its
equivalent. (Lube kit is sold as additional equipment. )
CLEANING
The read head and contacts should be cleaned regularly with a fine
brush and clean cloth. To gain access to the read head, rermove
the one screw on the front of the head cover and withdraw the cover
away from the front panel.
CAUTION: Do not disarrange the small wires of the movable contacts.
IMPORTANT: Keep the star wheels clean and free of dust, lint and
hair, so as to keep free rolling.
PARTS REPLACEMENT
If erroneous readings occur, examine contacts for dirt or pitting.
Replace pitted contacts.
READ HEAD ADJUSTMENT
Reading errors may be caused by incorrect adjustment of the read
head assembly. Check if each of the eight star wheel levers are free
to move in a vertical direction without any drag on the adjacent levers.
DRIVE SYSTEM COMPONENTS
Damaged gear or shafts may be replaced by loosening all set screws
which clamp the gears to the shaft and slide the shaft axially through
the bearings.
CAUTION: Do not disassemble the frame members. Preserve
all the shim washers disassembled. It may be necessary to add
or leave out shims when new gears are installed.
ESCAPE ACTUATORS
An open or shorted coil may cause the escape actuator to become
inoperative. The pivot slot in the pallet lever may also become worn
excessively after long operation. Replace the complete actuator
assembly in either case.
