What is a Braking Resistor? I'm assuming it is added to a motor circuit to help stop a motor.
Quote from: drodriquez on October 02, 2017, 06:40:PM
A braking resistor is an energy-absorbing electrical component (resistor) that dissipates energy from a decelerating motor load. Load inertia causes the motor to act as a generator during deceleration and the heat generated in this process is dissipated through the resistor.
Thank You!
(https://www.obsoleteindustrial.com/photos/resistor-problem-solved.jpg)
