What is Input 2 Break Alarm on a Parker AC Drive?
Started by rickpend, October 06, 2016, 10:20:AM
What is Parker INPUT 2 BREAK alarm mean on a Parker AC drive? I'm looking for a simple explanation as to what input 2 break means.
And how do you clear the input 2 break alarm from a Parker AC drive?
Quote from: rickpend on October 06, 2016, 10:20:AM
from the manual: A signal break has been detected on analog input 2 (terminal 2), Analog input is incorrectly configured for 4-20mA operation, Break in external control wiring
To clear the input 2 break alarm, you will first need to find why it appeared in the first place. If this is a new installation, you can go straight to the input parameters and check that they are configured the right way. If it is an existing application, it is more often a wiring problem, you will need to retrieve your ohmeter/voltmeter and go to work.
