What does Excessive Gain mean?
Started by travis, March 28, 2016, 04:04:AM
What does "Excessive Gain" mean?
What does excessive gain mean? Can someone provide a basic explanation or definition of excessive gain pertaining to a motor. Thank you!
Definition of excessive gain: In relation to a motion control system, excessive gain is the concept of generating high torque and large amounts of heat within a motor due to over-correction of a small position error.
Excessive gain can cause a motor to over-correct unnecessarily hard which is where the higher current and heat come from.
How to reduce excessive gain in a motor:
Well, your motor drive combo need to be addressed in some manner. Since most manufacturers vary on tuning techniques, you may need to adjust a pot, change a parameter, or even move a jumper to reduce excessive gain.
A properly adjusted motor will not get quite as warm. A lighter load may require less gain in your settings versus a load that is a greater strain on the motor.
