What is Brake Switch Alarm on a Parker AC Drive?
Started by rickpend, October 06, 2016, 10:29:AM
What is Parker BRAKE SWITCH alarm mean on a Parker AC drive? I'm looking for a simple explanation as to what Brake Switch means.
And how do you clear the brake switch alarm from a Parker AC drive?
Quote from: rickpend on October 06, 2016, 10:29:AM
The manual says: Internal dynamic braking switch has been overloaded. Trying to decelerate a large inertia load too quickly or too often
To clear a brake switch alarm, you will need to start with the dynamic braking calibration and verify that it is properly set up, next you need to examine the installation to make sure the load isn't too much for the dynamic braking system. It is possible to overheat the dynamic brake circuit if you are stopping the motor too often also... so there are few places you need to visit when you see this alarm.
