What is a Bad Input Command?
Started by travis, March 30, 2016, 04:20:AM
What does Input Command mean?
What is a "Input Command Alarm" in easy to understand language? Can someone provide a basic explanation or definition of a Input Command Alarm message and its possible causes.
I'm looking for tips on troubleshooting this type of fault from the perspective of an electrical maintenance tech. Thank you!
  • Input Command Fault
  • Input Command Alarm
  • Input Command Problem
  • Input Command Message
"Bad input command" seems like it should be a "bad command signal"
Definition of command signal: a voltage supplied by the controller in a motion control system that commands a precise movement of a motor within a specific time frame with the desire motion profile.
A bad command signal may indicate that the controller is issuing a command voltage that is out of range. I have to admit, I am not familiar with this error. Anyone else have some feedback on bad command signals?
